It is currently Thu Aug 07, 2025 7:33 pm
 Post subject: Sharpening Router Bits
PostPosted: Mon Apr 30, 2018 1:44 pm
Have any of you guys used a professional sharpening service for router bits? I a thinking specifically of my LMI binding bit.
If so any recommendations?
I have those diamond abrasive sticks but have not found them optimal.
Terry
PostPosted: Mon Apr 30, 2018 2:34 pm
I'd be worried that the sharpening could throw off the calibration of the depth of cut...
PostPosted: Mon Apr 30, 2018 2:59 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
That was my first thought too for the binding bit. However, I always make test cuts on scrap wood to dial in the set up before routing the actual channels on the guitar so that would provide a way to take into account any change in the depth of the bit.
Is there any concern in general when sharpening router bits with putting them out of balance?
PostPosted: Mon Apr 30, 2018 3:16 pm
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
Sharpening router bits does change the diameter, certainly. I've used a flat diamond stone to hone some of mine, and just counted strokes to make sure I didn't mess with the balance. Never had a problem.
PostPosted: Mon Apr 30, 2018 5:21 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
My experience with professional sharpening services and bits with a spiral helix is that they spin both the bit and the wheel to sharpen. It should not throw off the balance, at least it never did for me up to 10,000 rpm. It will change the size and it depends on how bad your bit is and how much they have to take off.
If its not a spiral helix, as in a straight edge, you can sharpen it on the interior face with a fine grinding wheel and not change the size. Once again how much you have to take off depends on the wear. I like this way better because you don't change the relief angles on the back side of the cutting edges. Best way to sharpen a counter sink too.
Either way they never seem to last as long as the original.
PostPosted: Mon Apr 30, 2018 6:11 pm
If it is just dull and not chipped I have had good results using a credit card sized fine grit diamond stone. Just gently hone the flat surface of the bit (not the bevel). It would take a lot to change and the diameter, but not that much to get it sharp again.
Kent
These users thanked the author kjaffrey for the post: dzsmith (Mon Apr 30, 2018 8:35 pm)
PostPosted: Mon Apr 30, 2018 9:07 pm
Sharpening services usually give you two to three sharpenings before the carbide is too thin to sharpen. They generally grind off a noticeable amount of carbide. If the bit doesn't have chips then a diamond hone may make it reasonably sharp and extend the life of your bit.
PostPosted: Mon Apr 30, 2018 10:17 pm
Thanks guys.
PostPosted: Tue May 01, 2018 6:29 am
Last Name: Orr
Sometimes it is just a build up of resin on the blade. I soak mine in spray oven cleaner and give them a scrub with an old toothbrush and it does make a difference. Bob
These users thanked the author Bob Orr for the post: Bryan Bear (Tue May 01, 2018 9:12 am)
PostPosted: Tue May 01, 2018 7:17 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
acetone or laquer , with a oily lubricant PB blaster and wipe off with plastic toothbrush, clean with a blast of air. diamond paddles from coarse to extra fine at HF LV or woodcraft
PostPosted: Tue May 01, 2018 8:41 am
City: Escondido
Zip/Postal Code: 92029
A straight bit I understand how to hone with a small diamond card. But how do you do a spiral bit by hand?
Users browsing this forum: bftobin and 27 guests
